Been playing this, looks okay cannot believe they still have not sorted the FOV out after all this time lol.
Still for free not so bad
If you want to fix the FOV, the way i do it is open user.ini, which is in
AppData\Roaming\BioshockHD\Bioshock
Change (i do a find and replace all instances but may not be necessary)
W=MoveForward
to
W=MoveForward | SetFOV 90
Or whatever fov you want, that way when you move forward it changes the FOV each time as the game tends to set it back to 75 so makes it playable
