Just wondering as a mate has both cards and is willing to lend me one while I save for my bettercard from ocuk
I have 2 machines, 1 AMD and 1 Nvidia and have had more AMD cards than Nvidia so no I certainly am not a fan boy. I have found much more games work better with Nvidia and come ready for Nvidia from the games I play (1600 on steam), and I have always had issues with AMD drivers on every card I purchased from them and rarely issues with Nvidia. The extra 2gb vram is also something that sways me towards the titan.
If you are just getting a loan of a card for a short while than just pick whichever one interests you most.
The only thing I will say is that if you are planning on buying an AMD card down the line than consider getting the 470, or the titan if you plan to buy a Nvidia card. That means you won't have to worry about running ddu or anything like that. Just install the card and go.
Where have you been for the last couple of years? Honestly, if you are going single GPU both sets of drivers are as good/bad as each other. However if you are thinking of going multi-gpu than Nvidia is streets ahead.
I don't think the Vram argument works in this case either. The Titan was surpassed by 4GB cards within a year.
Get the 470 if you are planning to then buy it from your friend, I presume it's a 4gb model.Both cards are for sale. So I was going to loan one for a week or two then buy it. The titans more expensive
470 is miles better than the original titan. This is just your usual misinformed tosh. I have a 470 and I think its great for the price. You can't really see much difference between it and the 480. Overclocks well too.
I don't agree at all, AMD drivers are just plain crap.
