- 23 Sep 2009
- London
Everything is connected fine and appears to the working, next step is getting everything calibrated, curves setup etc.
I am using an internal USB extension card. Pins 1 - 5 are reversed on two of the devices(?!?!!?). Luckily the ones I connected incorrectly were the res and flow sensor rather than the pump and controller.
I presume you're using the latest Aquasuite 2016 then? And updated the firmware?
Yeah that's why it's best to use the USB cable they give you instead.
