Stick VW logos or BBS logos in the circle in the centre caps and I'll be even happier![]()
The important question is, did you do it spectacularly?
Not bad for £20!
Yeah I think so, had it remapped on the stock 330cc injectors but drove like it was lean... The guy offered to have me take it back and check but I had the cam and 380's ready to drop in before he tweaked it...
Done maybe 100 miles on this setup now and it has driven much better, checked the plugs and did a compression check and it all looks pretty sweet.
140/130/140/130 across the 4 cylinders so seems fine for an angine on 97k
Its a win in my book, its done less miles than the one I've destroyed, and I only had to drive up to Rushden to collect it
Fitting yourself?![]()
I wish I had the knowhow/patience for that.
Do you do this stuff with the car on axle stands, or do you have a more elegant solution?
We've got some stands made of 1"x1" box section and right angle mild steel that stand about 300mm or so tall. Just a case of jacking the car up then dropping it down on them
Ordered a new barge. 2.2L Santa Fe. In super easy to keep clean black. Over 30k and you still have to push them to throw some mats in.![]()
Brake light wasn't working on Focus. Bulb looked ok but changed it anyway. Still not working. So used sandpaper on the contacts. Works again now.![]()
