- 11 Sep 2009
- France, Alsace
What other trainers should I be looking at in the £250-£450 ballpark? I'm after full smart resistance for control on Zwift/TR. Ideally ANT+ FE-C & BTLE compatible (future-proof), able to handle minimum of 800W (guessing 600W sprints?) and ideally over 5% elevation simulation (anything close to 10% or over would be a big plus). Vortex/Neo (or whatever Tacx one they're currently shifting) always seems to fit the bill, just they're so damn ugly in white and look flimsy...
EDIT: Can't 'justify' a full KICKR (other half said no) but equally if I did I couldn't justify then looking at PWM's next year...![]()
Now this is where things take a bit of a left-turn off the road of normalcy: The unit doesn’t support ANT+ (any variant, including FE-C), or even standard/open*Bluetooth Smart.* Rather, it only supports a closed/private Bluetooth Smart protocol instead
Bet you're still in summer jerseys in the south! Real hardmen!or just ride outside![]()
Yeah I'd already mentioned that, to be honest it would have to be heavily discounted to make the upgrade a viable option.I presume you've read the DCR article on the Kurt upgrades?
http://www.dcrainmaker.com/2016/09/kinetic-smart-control-trainers.html
They aren't ANT+/FE-C
Yup, can't wait! Although much of the 2015 guide still stands, with the Tacx Vortex Smart being still available and probably the trainer of choice. The colour is probably the only thing putting me off currently...DCR should be doing his TT roundup soon so that might help with the buying decision.
ILong sleeve jersey - Weird cut that bunches around my stomach and sticks out in a baggy bulge
Bet you're still in summer jerseys in the south! Real hardmen!![]()
I think the wind resistance calc still needs a bit of tweaking, at 45-50kmh it should be impossible for someone to ride away from a bunch.
Belgian distribution!Annoyingly I have 2 outstanding orders from Bike Discount that still haven't arrived. One from the 29th Sept and one from the 4th Oct, yet those underlayers arrived and I only ordered them on the 7th! Hmmm
Classic symptom of a jersey designed by a 'normal' clothing designer and not taking into account the riding position (i.e. designed around someone stood, not riding).top rolling up over my stomach
Entirely possible!If you have slip issues then it's purely down to you not tightening things enough.
I've barely got the InRide working - finally got it to appear in kinetic.fit last night on the 2nd new battery (plumped for some 2 for £4 Duracells!) but no power readings in the app. It would link to Zwift's power data but when it did I had 5000rpm cadence and no power/speed being produced. I've no idea if the rolldown calibration is even integrated into the android app/Zwift or is it within the units firmware itself? Everywhere else talks about using TR, may have to reinstall it but no idea if I can use it for calibration without an active subscription.If you're using the InRide it's really simple to tell if it's too tight or loose so I'm not really sure why this is even a concern. Do your warm up then do a calibration and adjust as it suggests.
