Try changing those to single display performance mode and adaptive power - unless you are running more than one screen.
I had sort of assumed that it was a driver issue. But was interested in other people's comments.
Though in my case, capping the refresh rate to 120hz does appear to sort it. only a work around obviously.
Though changing the two settings in the nvidia control panel that Rroff mentioned, does also appear to sort it for me and allows me to put the refresh rate back up to 144hz. Though I suppose it might be a random problem that will re-appear again. Time will tell☺
Does Nvidia have a report form?
I have the same EVGA graphics card paired with an ASUS rog swift monitor at 144Hz + latest nvidia drivers (373.06) installed and I don't see any noticeable flickering.
Although I did have some other issues such as webpages glitching when scrolling. I sorted this issue out by using DDU to remove old drivers and doing a clean install of the latest drivers.
Hope that helps.
Came across this thread after ordering a 1070 and an Asus VG248QE - any points to note when setting this up? e.g. latest drivers ok?
