Why is everyone referring to this as a beta?![]()
Cause that's what they called it. At the moment you are playing the beta until the 18th
Has anyone had any luck connecting to Operations? When it can actually find a server I just get an out of sync cinematic about Amiens then the screen goes back and I get sent back to the menu.
I've played the trial for nearly 10 hours now and not 1 battle pack has dropped for me.
Seen the same players getting drops 2 rounds in a row! Anyone else had this?
Couple of noobie questions if I may (not played much of any bf game before)
When you play as support and use up your mortars, is there a way to restock them before you die?
Same goes for ammo packs, do you have a limited amount to give out?, and how do you get the ammo crate.
Best place still via VPN? If so, where should I be looking at flights for?
the cool down for the mortar is less than 1 minute.
Cd keys still cheapest I think
Just play on a server that has 50% health, same difference and you can disable the hud for a better experience also.
As said before I noticed people take time less time to drop in bf1 normal mode, not like BF3/4 where you could empty a whole clip and the other chap would turn around and 1 shot you, maybe the hit boxes are perhaps better.
