Audi owners in here!
jbs
jbs
27 Sep 2009
London
Hi I am trying to send destinations addresses using the Android app for audi and it doesn't seem to work?
The only feature that works with the app my a3 is the car finder.
Any suggestions?
I've got it to work on my A6, which is slightly older tech, so we don't have the car finder. I've done it through the Audi Android app and directly from google maps. Are you going into the correct options to retrieve it when in the car? This is where I initially went wrong, I though it should be within my directory. I think the correct option was "online destinations". Have a look and if you can't find it I can confirm when I have a enough energy to drag myself outside to the car.
jbs
jbs
27 Sep 2009
London
I've just seen the pictures of the new Q5, and disappointingly they are following the trend with the A4 and A5 to stick a tablet on the dash. I cannot believe there are people that like this. Do they not get feedback that it just looks like someone forgot their tablet in the car and does not look good at all? Or am I on my own here. Either the previous A4/Q5 where the screen is integrated or the current A6/Q7 where the screen can be hidden would be better.
LiE
LiE
Caporegime
2 Aug 2005
Milton Keynes
Cross post from my other thread - I picked this up this morning.
A4 S-Line 2.0 TFSI S-Tronic Quattro 252ps. Lovely lovely car.
Caporegime
29 Jul 2011
In acme's chair.
Very sleek and modern, but more than a little bland.
And why have you glued a cheap tablet to the dash? Looks awful. ;)
I bet that engine/drivetrain combo is great though. :D
5 Mar 2010
Has anyone had their car in the software/hardware change due to EA 189?
Had a letter yesterday telling me they they'd be in touch soon regarding if it needs to be recalled.
So i had a bit of a read up to see what the recall action consists of, and what implications this has for the car - performance/economy etc.
As mines a 1.6 it appears it needs a software and hardware change, and will need to be fitted with a "flow transformer" device - helps calculate the correct amount of fuel and air being combusted.
However Audi don't seem to give any official information regarding the implication of the software update and hardware change. The article i read touches on compensation claims from various countries, and it seems UK/EU owners have been rejected compensation on the grounds that the repairs will have no impact on the cars performance or economy.
However i'm a little concerned that the repairs are likely to push the emissions up, and thus cost more in VED.
Anyone able to comment on the changes?
5 Mar 2010
[TW]Fox;30117499 said:
VED is based on reported CO2 emissions at the point of registration. It is not retrospectively changed.
Ah perfect, thanks for that.
So cost to owners is effectively null. Assuming there are no implications to performance/economy - which there doesn't seem to be a great deal of info on.
21 Jul 2008
I personally wouldn't do it. The fix HAS to affect something. If they could get the same performance and economy for the amount of emissions produced, then why cheat in the first place?
I have heard, anecdotally of course, that some people who have done the change have had significant losses is economy, or performance, or both. I personally wouldn't do it unless there was either some form of compensation, or you were forced to for warranty purposes or the likes.
I certainly wouldn't be doing it just because.
5 Mar 2010
I'm not aware you have a choice?
Surely if the amount of NOx emissions exceeds guidelines without the cheat device, then it wouldn't be allowed on the road?
27 Feb 2006
Lincolnshire
Very nice but you should have pushed the rear headrests down before you took the pictures ;), my A4 is now in the country and I am going over tomorrow to do the paperwork so I might have some pictures. Collect the car week on Friday...
