- 15 Dec 2008
ouch made me wince, you have my sympathies looks painful.
You should rub butter into it, it will replace the lost oils that have been evaporated and help with healing. The oil in the butter will help you and the salt in the butter will help with sterilization.
To be honest cannot believe people still use hot water bottles!![]()
I'm all for basting my meats but dude...long pork?
Soft butter or margarine works wonders for burns.
Also helps with reducing scarring.
And friction burns.
Need some on your old chap and some on your misses knees.
Luke will be along shortly to say you shouldn't have called an ambulance out for that!
People still use hot water bottles?
Happened to me with a kettle when I was 11.. I'd rather brake bones then get burnt.. feel for ya![]()
Me neither. They just seem so old fashioned, like something people took to bed before central heating and double glazing, otherwise they would have rigor mortis within 10 minutes.
That looks nasty.
Manufacturers always say not to fill more than 2/3rds, to expel any air and not to use boiling water.
ouch - feel for you - I burnt myself knocking over my freshly filled caffetiere (750ml one) all over my leg earlier in the year - it felt like knifes digging into my leg
you need to get it checked out ASAP - I went to A&E with mine - they cleaned it all up etc - but more importantly is depending on how bad the burn is to get it dressed - as it will heal but you must not get it infected
