What CPU?
i5 6400 running stock, cpu temp mid 30's to low 40's under load, Gpu temps are 75-80 under load.
What CPU?
OcUK have the Sapphire 480 Nitro+ OC 8GB in this week only. I'm tempted.
The this week only price isn't that great tbh.....
the 4gb should be fine for 1080p gaming...I guess if you plan on buying a 1440p or 4k monitor in the future then the extra GB will come in handy...then again questionable as to whether the card is powerful enough for anything above 1080p.
I could boil an egg on the back-plates of my MSI gamingXs. Top card is hitting 81c, bottom 75c... with the front of my case off, 2x140mm intake fans, the side of my case open and a full PCI slot of space between the cards, even then, the top card is still struggling to hold 1303mhz
This is with -48mv and a +50% power limit, is this expected behaviour as they where quoting temps in the 60s on reviews
Fan speeds are automatic but top card hits 80% and bottom 39%
This is while using 3Dmarks stability test, which I can only pass with the above case and config layout.
The only cards that are in the high ~50c and low ~60c are the XFX GTR XXXs (running 95w-105w) confirmed by JayzTwoCent and a friend of mine that has a big mining operation.
Note: Are you running Crimson 16.7.1 or higher ? I've read that these sort out the wattage problems that were affecting users earlier on.
Add me![]()
Add me![]()
On BF1, I've switched to DX11 for now with my 480 4GB and it's stopped stuttering on ultra.
