https://www.reddit.com/r/buildapc/comments/58hnzb/word_of_warning_the_evga_1080_blackscreenfan_bug/
Anyone encountered this problem?
Nah, as the card would need to be under heavy load for an extended period to warm up to the point where this could be an issue, which won't happen during startup.I have been having issues with my computer resetting on boot since installing the 1070. Wondering if this could be related?
These hot spots are nothing new either. Plenty of cards from all different manufacturers have had them over the years. Here's a Titan X for example:
Of course, you may expect better from a custom cooler, especially on a card that draws a lot less power than a Titan X, but I'm sceptical as to whether it's actually causing any issues.
Could it be different memory chips back then that could handle higher heat?
On pascal cards the ram can only handle 95C
Pascal cards use a variety of different memory chips, incorporating both GDDR5 and GDDR5X as well as both Micron and Samsung, and even different specific parts within all those parameters. For example, the Samsung GDDR5 on Pascal cards incorporates at least the parts K4G80325FB and K4G41325FE, both of which are rated for 8GHz. Unfortunately, Samsung don't seem to publish operating temperatures for their GDDR5.Could it be different memory chips back then that could handle higher heat?
The VRMs would never be an issue for temperatures in the 90s though, because they're always rated much higher than that (usually around 120-125°C). The implication here is that heat generated by the VRMs is spreading to the VRAM and affecting its operation.It is not the VRAM that is the issue here guys, it is the VRM's - the voltage regulator modules.
According to that article EVGA state cards built before August 31st have this issue, those after do not. My 1080 FTW was ordered on... August 4th. Oh joy.
I havn't had any black screen issues though its coil whine drives me nuts. Is it just me or does it not have any temp sensors on the VRM's? GPU z nor HWMonitor doesn't report anything but cards I've had in the past certainly did. Hmm.
Only card I have had in recent memory that could monitor VRM temps was a 7970. I am pretty sure that all my recent Nvidia cards (780Ti's, 970, Titan X and 1080) do not give this temp reading.
