Caporegime
- 30 Jul 2013
It's actually a TH-50PHD8 'Monitor'
No speakers, very few inputs (You had to buy add-in boards)
I think I've gotten very lucky with my Samsung 55KS7000. The back panel is firmly in place, no dead pixels and very well controlled light bleed in extremely dark scenes - nearly non existent.
Funny, as I had already mentally prepared myself for at least 2 trips back to the store.
Software come with v1132 and upgraded to v1142.
Netflix 4K looks incredible, especially the HDR shows. Very happy, bring on the PS4 Pro tomorrow!
Nice! Mines arriving in 30mins back home
Does it upscale standard ps4 or is all that tied to the pro?
These problems you were maybe expecting, how do i notice them as a nok tv enthusiast?
Dont want to take delivery of a broken unit and not realise until down the road sometime!
When you get it out the box check the black back panel, the build quality on these isn't fantastic and the panel is held on by glue. Make sure it's not coming away from the back of the TV. It'll be pretty obvious if it is.
Pause the video/game on a bright scene and carefully look all over the screen closely. Look for any spots where the pixels are dead, will look like a very small dark flecks.
Pause the video/game on a dark scene and look for areas/patches of light, these are normally found on the sides. Most edge back-lit LED TVs will have light bleed to some extent, but some are better than others. It's luck of the draw with how yours is. If it's really bad such as bleeding across a big portion of the screen or particularly bright, send it back. Also worth looking for any stuck pixels at the same time.
Just make sure you don't turn on HDR+ by accident.
Whats that?
It tries its best to convert SDR to HDR.
Not a fan of Samsung generally and have always bought Sony TVs and loved them. What is the nearest Sony equivalent to the Samsung s7000 in terms of 4K, HDR, and input lag?
Is the ks7000 the best bang for buck TV out at the minute then?
