 - 23 Dec 2009
 - RG8 9
My 390 still has legs in it.![]()
Pretty much a 480, I expect my crossfire setup to last quite a few years.
).I used to ****ing love my Crossfire setups tbh (except the 290X Reference one, that just downright deafened me!!!!).
How are you finding it atm? Well supported generally?
Have a read in the AMD driver thread, crossfire generally sounds like a flickering light show in many games, BF1 included.
 There have been some issues mind, mostly heat related, the fans actually spin in 2D which is annoying as that's one of the reasons I went with MSI. I think one card is a bit iffy  and is spitting out coil wine but can't get to the bottom of that with the system being down. I have to say, though, it is insane how hot these backplates get, 70c easy. They look awesome, though. Especially with the RGB LEDs set, shame I can't use the LED software because it's buggy as ****. Ha, the problems I have had with this build :SI also add that with an AMD setup you also save money on your monitor as you don't have to pay for a g-sync module so the equivalent screen is £150-£200 cheaper.
Certainly something to consider.
yep same here crossfire experience has been pretty good over the years and ive come close to buying a pair of 480's but posts from loadsamoney and tony turbo keep putting me off
Forgive me for butting in but you mention that dave's post is only using a certain resolution, and totally ignore that floppers graph only put the fury x above the 1070 @ 4k by 2%, the rest of the resolutions have the 1070 being on top.
Now THAT is a "Cherry Pickers Dream".
Yet another game where the 1060 beats the FuryX, hadn't seen these before, thanks for posting.
Crossfire has been utter **** for the last 18-20 months man, hence my switch to the Dark Side![]()
Last time I head SLI was no better and even places like Anandtech are saying it's down to modern console orientated games.
I definitely think consoles are holding PC development back and have been for a few years. Surely, you would think that would not/should not be the case (especially for AMD/GCN).
Well there will definitely be plenty to talk about in 2017, that's for sure.
Well with the PS Pro coming with a dual GPU setup we might finally see developer pushing for explicit multi adapter in DX12.
Might be entirely wishful thinking on my part, but Raja said they were pushing for multi GPU to become as common place as multi core'd CPUs.
i read gears of war 4 is supposed to get multi gpu support but by the time that ever happens i will have finished the game
