- 11 Sep 2013
But this thread is about bacon sandwiches....I know, that's why I said that is how I prefer it, over a sammich, which is usually too much bread.
If it's "too much bread", you need more butter to melt in and more juicy bacon!Bacon to bread ratio is important.
That says "pieces of bread", although most other sources say "slices", which is further supported by the classic Sandwich Loaf, designed with this very purpose in mind.It is if you've cut the roll,bap or sub in half giving you 2 pieces of bread and we're going with the oed definition of sandwich.
Furthermore, what idiot outside of McDonalds would completely separate a roll, bap, sub or French Loaf like that?
Cut into it and fill it, sure... The last one especially, since that what the Breakfast Box is all about... but completely in half?
That would mean you never eat a burger, but instead have a 'beef pattie sandwich', or some such moffie kak? No thankyew!!!
It's also mean a sausage sandwich and a hotdog were the exact same thing.... which they are NOT!!!
It's called a bread roll for a reason.On second thoughts this very much depends on if you class your bap,roll or sub as being bread
Also, I don't really recall baps and subs when I was growing up. They're a bit of a new thing that appeared when Starschmucks did.
What kind of loaf?or if bread only applies when it comes in loaf form. Mind. Blown.
Farm loaf, square loaf, plain loaf, French Loaf, sliced loaf?
