Caporegime
- 9 Nov 2009
- Planet Earth
Yeah, I'm aware, sadly.
But because the 5820 existed, a product coming out years later at a similar price point isn't special. And if it has Haswell type performance, it'd be a pretty similar performing chip too, for a similar type of price.
Either way, a 300 pound 6C/12T chip with Haswell type IPC which is available is still very very good, and cheaper than current i7 4c/8T prices.
Well a 4C/8T chip with reasonable performance for around £200ish(subject to the pound crashing even more),probably would do me fine.
After looking at how BF1 loves threads,as long as the lowest end Zen has reasonable IPC I suspect it will be a decent seller.
I am also a bit more confident about Zen now - the fact that are targeting a higher end price means,means it probably is competitive compared to even the Intel 6C/12T chips. I suspect Intel will still have the single threaded performance lead,but as long as AMD can close the gap,it should be enough especially if the power consumption is now more under control.
The chip is also probably much smaller than previous AMD ones too,so hopefully they should be able to turn a profit now.
