** macOS Sierra / OS X 10.12 **
  • Thread starter Thread starter Deleted member 651465
  • Start date Start date
There seems to be some sort of mission control feature in Safari that i've triggered a few times unknowingly, it displays all the open tabs but in a mission control type way. Does anyone here know what the gesture is for that? It's useful, i'm just not sure how i'm triggering it. Can't seem to find the correct terminology to find it on Google either.
You're using Exposé to open the application windows. Have a look at the keyboard and you'll see the 3 squares on one of the function keys... there's an option in System Settings to change that to application windows only or the easier way is to look in the multi-touch gesture settings on the trackpad (two fingered pinch to zoom out).
Not sure about the gesture, but it's the button on the top right that looks like a couple of squares, one behind the other.
Thanks, that put me on the right path as that button is for 'show all tabs'.
The gesture is two fingered pinch :)
Does anyone know of an app that can allow me to manage/close my open windows easily? I found one via Google called Hyperdock which allows you to see a preview of the open windows by hovering over the Dock icon (just like Windows). I don't wanna pay for it if there's a free alternative though
Just upgraded to Sierra as I was initially put off by the fact that Endnote reference manager wouldn't work properly. Our VM internet was seeming to get worse and worse and I'm sure that it was El Capitain that was causing network problems. So far, so good. The software update appears to make my connection to the router much more stable and finger crossed this will sort everything. Endnote appears to work still which is nice, although I think I'll need to update McAfee virus scan to version 10 for full functionality.
So far, so good.
macOS 10.12.2 has been released and is now available through the Mac App Store
macOS Sierra 10.12.2 Update
The macOS Sierra 10.12.2 update improves the stability, compatibility, and performance of your Mac, and is recommended for all users.
This update:
  • Improves setup and reliability of Auto Unlock
  • Allows addition of a Chinese Trackpad Handwriting button to the Touch Bar Control Strip
  • Adds support for taking screenshots of the Touch Bar using the Grab app or Cmd-Shift-6 shortcut
  • Fixes an issue that caused the Touch Bar emoji picker to appear on the display
  • Resolves graphics issues on MacBook Pro (Late 2016) computers
  • Fixes an issue where System Integrity Protection was disabled on some MacBook Pro (Late 2016) computers
  • Improves setup and opt-out experience for iCloud Desktop and Documents
  • Fixes an issue with the delivery of Optimized Storage alerts
  • Improves audio quality when using Siri and FaceTime with Bluetooth headphones
  • Improves the stability of Photos when creating and ordering books
  • Fixes an issue where incoming Mail messages did not appear when using a Microsoft Exchange account
  • Fixes an issue that prevented installation of Safari Extensions downloaded outside the Safari Extensions Gallery
  • Adds support for new installations of Windows 8 and Windows 7 using Boot Camp on supported Macs
Nice way to quash people's complaints of bad battery, by just removing the "time remaining" estimate.
Don't fix bad battery life, just hope people don't notice. :D
I'm going to do a fresh install of 10.12.2 when I get into work shortly. It's always nic to have a fresh install now and again.
Can't say I've ever noticed a difference between a fresh install and an upgrade.
Agreed. I did a fresh install once after years of upgrades to see if I'd notice any difference and there really wasn't any. I truly think that you're wasting your time.
Finally install macOS Sierra. I'm glad I was able to turn off Siri from the get go! Also told Apple not to upload my documents to the iCloud, as I'd need to pay to upgrade. My documents folder has 24gb in it. I'm also on the verge of buying Google Drive space as well. So it wouldn't have gone down well!
However, what I find a little uneasy (despite me telling Apple not upload my stuff to the cloud) I now have 20gb more space free after the upgrade. I'm wondering what it deleted, hmmm.
Everything seems to be intact though!
Upgrade was smooth as expected. Laptop running really well so far :)
EDIT: MS Office wouldn't open afterwards. But I ran the auto-updater and it patched it, it's now working again!
Overall the laptop seems snappier. Graphically smoother as well. Impressed so far! Although I'm quite sure I am not utilising a single new feature from Sierra :p
macOS 10.12.3 has been released and is now available through the Mac App Store
  • Improves automatic graphics switching on MacBook Pro (15-inch, October 2016)
  • Resolves graphics issues while encoding Adobe Premiere Pro projects on MacBook Pro with Touch Bar (13-inch and 15-inch October 2016)
  • Fixes an issue that prevented the searching of scanned PDF documents in Preview
I'm still running OS X Yosemite on my iMac (late 2009 - so quite old now). Is it worth upgrading to Sierra or will this have a negative effect on performance?
Interested to see if anyone else has upgraded an old Mac.
