Ordered a Renthal Ultra Low handlebar, let's see how it goes...
758? What bike are they going on?
The last time the weather was this bad and I ended up riding down the A449 behind a wall of water I stopped for a chat with a guy on a Vespa that had just done the same thing.
Still the only scootay rider I nod to because it was touch and go for me so I can't imagine what it was like on one of those little things!
I had to google what Afsluitdijk was as I thought you just bashed your keyboard![]()
Emailed SBS this morning as the pinlock on my Schuberth just isn't sealing correctly due to the pressure put on the pins popping them out just enough to lose tension and break the seal.
Apparently the guy replying to me suffers with the same problem and it's quite common from what he's said.
The fixes he gave me were
1. Rotate the posts to their outermost position, flex the visor outwards and install the pinlock insert.
Or;
2. Carefully file the notches of the pinlock insert so there is a little more room for the posts.
I've already done number 1 and the pins are too loose in the visor holes to hold the tension and 2 seems like a pretty rubbish workaround for what is the most expensive non race rep helmet on the market pretty much but due to its design it's impossible to ride with the visor cracked open enough to keep it clear as the air comes straight into my eyes reducing me to looking through tears pretty quickly when it's cold enough to need the pinlock.
They've said I can send it back for inspection but as it sounds like a common issue that seems pretty pointlessso at the minute I've had to go back to my old Shark S900C.
Not overly happy.
I'm considering a dab of superglue on the pins, but then I imagine if it still doesn't work I'll then have no recourse if I send it back.
Go with a Shoei, Japanese quality.![]()
I do love my Shoei. Super comfy and light.
You can normally rotate the pins between their outermost and innermost position to get the tension right, the posts are elliptical.
The only issue I have on my Arai with the max vision pinlock is a slight bit of fogging up (less than a cm deep and 2cm wide) right where my nose is, and only on really cold mornings (2-3 degrees or less).
I'm not that bothered, its just not logical going through all the hassle selling the bike, buying another one going through insurance etc.
I know someone who changes bike more often than you, but he makes profit on them.![]()
I've them on my SV, they're much better than the stock although I can't squeeze through tight gaps in traffic like I use to.yeah... SFV650 Gladius
Now you're just BS'ing...It's also not logical buying a bike and immediately spending money to change the bars before i even ride it.![]()
No I'm not, the last thing I want to do is spend money on a new bike, given my track record of selling on so quickly, it isn't wise spending money straight away.
For a man who doesn't care you seem to be talking about it a lot...![]()
+1, you aren't alone. I had to google it too.![]()
