Received my bundle, thanks again ocuk for a great deal. I do have one small problem - the two fans for the aio cooler do not have extension cables to connect them to the mobo, am I being stupid or should there be some with the kit?
Also, does anyone have the overclocking instructions? Apparently, they are on the forum somewhere?
They should be there. Mine was the same. I called customer service and they are getting a set sent out to me. Mildly annoying since I can't build the machine till they arrive, but these things happen.
Ok will have to drop them a line to get some sent out too. Regarding the mobo's W_Pump header, the manual describes an electrically different pin arrangement than standard PWM headers - i've googled it and general consensus seems to be that this is a manual typo and this header can in fact be used for standard three or four pin pumps and fans: can anyone confirm this at all please? (I would like to plug the aio pump into the W_Pump header on the mobo if I can to free up a fan header).
Yes Waterpump header works perfectly for the AIO Pump and put the fans ideally on CPU and CPU opt
I assume this deal isn't going on anymore![]()
). We are bringing it back on the 28th of December in limited numbers.Man if you followed the thread you would see we sold out by almost double of the first day (But honoured the over sales anyway). But we are bringing it back on the 28th of December in limited numbers.
