- 22 Dec 2006
- Around Town
Here's another one as Biggie would say
Rincewindle, it's cool and everything. And I'm fine with spending loads of money on something (I do it with restaurants). But, what are you actually going to be using that spec for?
To be honest.. No idea.
I just like the look of it.
Plus the last 2 pc's i have had i built myself from bits and pieces of old 2nd hand ones and odd and ends of parts from pc suppliers.
I wanted something that looked good with high enough specs to make it so i can use it for years without it having a nervous breakdown like my current one does. {gaming etc }
You could probably have made that for less, though!
Well i have ordered it
https://www.overclockers.co.uk/infi...erclocked-watercooled-dream-pc-fs-462-oe.html
If it gets here before xmas then i will be dancing round the living room like a loon
If not then i just need to buy some more coal for the coal powered pc i am running now.
The Joseph Joseph stuff is really good.![]()
