- 21 Apr 2016
- Oh Canada!
I just played overwatch at 140FPS and I think my eyes finished themselves off.
Interesting monitor. I'm curious at 24" vs 27".
Hey, ive had both! The only noticable difference really is the size tbh.
I would probably pick the 24" for absolute super serious hardcore fps gaming but the 27" has more wow factor with it being bigger.
Didn't the overshoot and grainy panel of the 27" bother you though as the 24" is free of these issues.
If he had A02 or later for the S2716DG then the screen surface is similar.
I got the Dell S2417DG monitor, and I think it is great.
The only thing that is bugging me is, the bottom left and right corners you can see a light bleed (not sure if that is the right description).
You can notice it when playing a game if it is in an dark environment. And if you are watching a movie with borders, you can see it in each corner.
Is there a fault with the monitor? or is it just the TN panel?
Thanks for any advice on this.
Do you think I could get it exchanged for another one then?
Yes, I am sitting dead centre of the monitor.
I have took a photo of a movie playing on it. If you look at the top border and then look at the bottom one you can see the difference.
It is doesn't come across well in the photo, but it is a bit more noticeable when you see it in person.
It is minor, and you could probably live with it. If it was you, what would you do?
