- 11 Nov 2002
- Scotland
RandomSSIDname
How would the name have any bearing on how hackable the wifi is?I believe a non unique ssid and simple password are easier to crack.
Mine is my last name backwards. Makes a decent random word that is recognisable, but not guessable.
There are two major parts to converting a password value to a decryption key. The first is called salting. It's possible you've heard this term used once or twice. This is a method in cryptography that prevents two systems from using the same key, even though they may share the same password. Without salting, a pair of machines using the same password, even coincidentally, end up with the same key. This is a vulnerability for rainbow tables,
Police surveillance cam 232
virus.exe
House LANister
Although I might enable one of the guest SSIDs again and set it to It Hurts When IP
