Games that are already designed to run at 60fps on consoles will inevitably run better on PC, too. And Doom is especially well-optimized. This is not the norm for AAA releases, though. Even though there's been a fair few quite recently with the multiplayer FPS trifecta of TF2, BF1 and IW.I played through a good bit of Doom on a 970 - 1440p everything turned up was most of the time comfortably well over 60fps.
Was a bit of a mixed story though - some older games where performance came down a lot to shovelling lots of primitive geometry, etc. my 780 could be quite a bit faster.
They are all old cards now though despite the justifications of some - if it wasn't for the fact nVidia have trickled out performance increments (and AMD were nowhere to be seen) they'd have been utterly obsolete months ago as developers targetted a new generation of hardware.
No one? Well you certainly went out of your way to make it sound exactly the opposite, as you were complaining about your 970, and Nvidia cards in general, not being good cards in hindsight. And then CAT rode that wave and was absolutely *insisting* that the 970 was not a great purchase and argued against it. And then you tried to continue that argument on without every clarifying you ever meant anything different. So please dont act like I'm just making all this up out of nowhere.Your complaint there is unwarranted.
Plenty of credit is given to the 970, i have said repeatedly they are both great cards and as far as i can see no one is denying that.
I will be disappointed if that is their best card after this long wait. If that is the case I will definitely be waiting for Volta. Hopefully that is not their best card and a third tier card or something.
By who?This is most probably the smaller version, as Vega was said to have 16GB memory from the beginning
No one? Well you certainly went out of your way to make it sound exactly the opposite, as you were complaining about your 970, and Nvidia cards in general, not being good cards in hindsight. And then CAT rode that wave and was absolutely *insisting* that the 970 was not a great purchase and argued against it. So please dont act like I'm just making all this up out of nowhere.
Well there is a wealth of info guesses after the NDA on that event lifted, so lets see what we've got.
8GB ram 'confirmed'
512GB/s memory bandwidth 'either 4 stacks at 500MHz or 2 at 1000MHz'
12.5 TFlop/s FP32
< 300w TDP in server style form (fanless)
Can you get 2G HBM2 stacks? I thought it was either 4G or 8G, which would mean 2 stacks at 1000MHz tying in with above.
NCU ? Is this the GCN replacement ? 'next compute unit'
The opposition for reference
Tesla P40 16GB GDDR5x ram (GP102)
345GB/s
12TFlops FP32
250w TDP in server style form (fanless)
So the first info on Vega is certainly looking good, AMD could have a real winner on their hands.
The only downside I can see is the power usage, which is 20% more than the P40, a little bit higher than I expected considering it is using HBM2 as well.
Overall good first look and info, hopefully we will get a bit more tomorrow with the ZEN event.![]()
"A Vega 10 has 8 GiByte HBM2 is unoptimized at GTX-1080 level"
A GeForce GTX 1080 overclocked at over 1,900 MHz is there about 10 per cent slower. Note, however, that first, no Vega-optimized driver was used, but simply a Fiji driver with a little additional debugging work.
Ah, "AMD Rebrandeon" again.
But I don't expect this will be true. Small Vega is said to be only 1TF or so faster than the 480. Therefore I personally expect Vega 11 to replace the 480, not coexist with it.
And if that's the case, then £270 for the cheapest small Vega is nonsense.
There's a whole lot more involved than just comparing a p40 inference accelerator vs amd's vega training accelerator.
You're backtracking hard man. Your whole point was that you were disappointed by your 970 purchase. Even after further arguments, you never once stepped in to say, "Oh they're both pretty similar actually, I think it's a great card". Nope. You specifically argued for exactly what I interpreted you to say(which was hardly ambiguous), even.Not at all, i think it has some flaws, i also think the 290 has some flaws, i have been vocal on both, thats it
Haha. Seriously, this is where it just gets sad. Everybody on either side always seems to think 'the other side' is the bad one. Can you really not see how there's a *whole lot* of AMD fans here who do the same things or worse? Well, maybe you cant see that, cuz you're one of them.it seems to me anything negative said about Nvidia, or even just not overly positive is like a red rag to some people, i think that is where you are getting this impression.
About the Doom Demo on Vega.
https://translate.google.co.uk/tran...als/Vega-10-HBM2-GTX-1080-1215734/&edit-text=
8GB ram 'confirmed'
12.5 TFlop/s FP32
345GB/s
12TFlops FP32
That would be awesome, even considering that Doom + Vulkan is an extraordinary case and the average would probably be somewhat less than a GTX1080. Still, anything better than a GTX1070 for *small* Vega would be great.About the Doom Demo on Vega.
AMD confirms the INSTINCT MI25 is a single GPU card:
Good find.
I assumed it wasn't a dual, but it is always nice to have confirmation.
From what I read elsewhere,apparently the card might have been downclocking a bit as the exhaust was partially covered by tape.
All Aboard!![]()
Nice to finally have something to talk about regarding Vega.
