It does seem off we're not seeing turbo in these previews, it's due for release in the next 2-3 months so final silicon must be available.
1H 2017 could mean June.
It does not look too shabby,and even if Intel wins a bit overall in IPC with KL,AMD looks like it will have something competitive.
The last time AMD could even compete with £1000 Intel CPUs,let alone £400 ones,was during the Athlon and Athlon 64 days.
erm the 6900k is a 140w part , zen is topping out at 95w
Performances - Gross Computation said:With its eight real hearts, Zen manages to realize prowess despite the limited frequency of 3.3ghz. It is even approaching dangerously - for Intel - of the Core i7 6900K with comparable performances of the Core i7 5960X equipped with an identical frequency (3.3ghz in turbo mode). AMD's allegations a few months ago seem to be well verified in practice and this is excellent news. Compared to the FX-8370, a performance gain of about 35% at an equal frequency is observed. Also in line with the manufacturer's forecast (40%).
Power consumption said:Measurements under full load (watts)
The electrical consumption measurement of the Zen CPU was taken at the amperometric clamp on the ATX 12V connector, under full load. Although it is less precise than the ones we usually perform on the oscilliscope, it gives a good idea of the performance of the 14nm LPP process of Global Foundries. After removing the VRM losses from the motherboard, it can be estimated that the CPU consumes just under 90W, a value very close to that of a 6900K. A good result for the future.
Although the Octo-core models seem well on the rails, the manufacturer must imperatively finalize the quad-core declinations with frequencies much higher than on the current prototypes: 3.8 or even 4.0 or 4.2GHz seems to us the minimum to go titillate the Last Kaby Lake.
Intel state its a 140w cpu and they make it , so I would rather listen to them , than some random website
oh and anadtech had it at above 140w under full load
http://www.anandtech.com/show/10337...900k-6850k-and-6800k-tested-up-to-10-cores/10
Power consumption was tested on the system while in a single MSI GTX 770 Lightning configuration with a wall meter connected to the OCZ 1250W power supply. This power supply is Gold rated, and as I am in the UK on a 230-240 V supply, leads to ~75% efficiency > 50W, and 90%+ efficiency at 250W, suitable for both idle and multi-GPU loading. This method of power reading allows us to compare both the power management of the BIOS and the board's ability to supply components with power under load, and includes typical PSU losses due to efficiency.
Look at the French results posted both are consuming between 90-95W at full load, TDP relates to cooling requirements. I ignored the game benchmarks as they're meaningless really, even AMD FX does well in a lot of games.
If CAT-THE-FIFTH is right about the 6900K running at much higher clocks then it's good news for performance but even worse from a power efficiency standpoint. I just assumed a 6900K won't boost very much when all cores are fully loaded.
I've just gone through the hassle of translating the productivity test text:
So Zen was running at 3.3ghz with turbo I assume? they say it's the same performance as 5960X at 3.3ghz but don't include that in the benchmarks go figure.
Whatever said and done,it seems IPC is more Broadwell level which is more than the 40% AMD touted so many times over Excavator.
In a recent Video about the Zen architecture, An AMD engineer said they achieved a 48% IPC uplift over excavator.
Yeah. In Lisa Su's presentation she said they aimed for 40% and best it.
Isn't Excavator like a 10% to 20% IPC increase overall over Piledriver??
