- 5 Sep 2011
- Surrey
I'm honestly not sure if I'm missing something in this. What's the significance of the fact an i7 6900K can approximate the same time as Ryzen 8/16? All that tells me is that Ryzen appears to have Broadwell-E IPC (even without turbo, which I assume everyone here left enabled on their 6900s?). That being the case, if Ryzen is less than £1,000 then it's winner winner chicken dinner?
I may have taken the wrong end of the stick but some of the posts seem to be 'Ah but look, my 6900K gets the same(ish) time as Ryzen'. Well, yeah... but it's a £1,000 CPU, and shouldn't it rather be 'Holy crap AMD are finally matching Intel's top desktop chip, and at 90W TDP instead of 140W'? As I said, I may be missing the point.
Glad you asked, firstly no the results posted are off boost on the 6900K to match the Zen results. At stock, the 6900K clocks up to a boost speed of 4Ghz.
When running on the same build as AMD did (2.77) The 6900K is consistently overtaking AMD's result. This particular point isn't of the most importance. The most important thing to take away from the very beginning is that everyone should be praying Zen overclocks well and that it's aggressively priced. Or else you've got an alternative that's purely only good assuming you underclock your 6900K or potentially, even 6 core BWE CPU.
In addition, this is purely when looking at rendering workloads. If we took other workloads into account, then the appeal is potentially even less.
