- 14 Mar 2011
Essentially I think that's what I'm going to have to do.
I was planning to record the DSLR separately. Pro tools will be recording to an external HDD (as I always do). I might try recording the DLSR straight onto the rMBPs SSD.
I expect that'll be okay... the only remaining thing you'll have to do is ensure you have a way to sync up the recordings... I think what I'd do is start recording the audio first, then clearly say into your mic "I'm pressing record on the DSLR in 3,2,1,now" and then do the same again for the game recording software, but make sure your mouth is visible in the DSLR shot when you do the countdown for the game recording. That will give you some clear points in the audio waveforms and in the DSLR to get everything sync'd up
If you want to be extra thorough you can then do a more traditional in-game sync (i.e. move the mouse between two defined points on the screen whilst vocalising it, like "new game - quit - new game - quit - new game" on a main menu or something). Hope that makes sense
(or do you have a helper?)
