Ouch that's pretty low mileage, even coming from me (I've seen 700/800 before now!). The 'rust' from road salt won't drastically increase wear if your chain was lubed to begin with, but lots of road spray combined with the road salt is very efficient at washing lube from chains, leaving the chain very dry (from the salt) if it is then ridden again (leading to much higher wear).
You can relube a 'rusty' chain and it'll generally clear much the rust away after some usage, but it is best scrubbed/cleaned first to remove as much of the salt residue as possible. Mine is looking pretty sorry for itself and around the 0.70 mark for most of it, some at 0.75. Once the roads are no longer being salted I'll replace it, but I'll certainly not be putting a new one on before then!![]()
You can buy anti-rust chains. They're powdered coated/galvanised.
Doesn't mean you can slack off with wet lube though.
I did it last year and was good fun, the app is pretty good too.
I'm going to have a large chunk left on my Cycle to Work voucher. What is the best all in one front light going? Bright enough for unlit lanes and ~3 hour run time would be good.
Never had problem with rusty chains. Even if I use dry lube, and it's washed off, and it rusts for a little bit (like a couple of links) then use wet lube use it for a bit wipe off rusty oil and re-lube it's spotless, and no stiff links. I don't use cheap chains though. KMC Z610 HX for the fixie.
Tempted, but don't think I could do it to myself (9 consecutive days on the turbo). Is it always 9 days/sessions?! Really need to try their new app, it's meant to be superb!Tour of Sufferlandria 2017!!
Who's in?? I'm going to try and give it a go. $10 for the app for the month, then cancel.
Haha yeah I always used to burn through KMC's, the KMC X11L that came on my Defy lasted less than 900 miles (through a winter). A Shimano CN-HG701 on there lasted 1500 miles (half a winter), on par with the SRAM PC1130's I preferred. The KMC X11 on my Diverge has done 1650 miles and still going (hopefully through this winter!). I've got 2 new PC1130's hanging around ready! (personally the best 11 speed chain you can get sub £20)I just checked and it came fitted with a £3 KMC chain so I'll not worry too much!
Anything Exposure and over 1000 lumen. Strada/Diablo. The Race could be a shout too. I would head towards the Strada as it's road orientated and has a superb mount.I'm going to have a large chunk left on my Cycle to Work voucher. What is the best all in one front light going? Bright enough for unlit lanes and ~3 hour run time would be good.
Thanks for this, will hunt one down for the other half as hers tends to get abused and hardly ever cleaned!Kmc ones are labelled EPT.
Holy hell, i need some brake pads that work in the wet, today's ride was nasty at times.
SS greens or KS Salmons still the ones to go for?
Yep.
Haha yeah I always used to burn through KMC's, the KMC X11L that came on my Defy lasted less than 900 miles (through a winter). A Shimano CN-HG701 on there lasted 1500 miles (half a winter), on par with the SRAM PC1130's I preferred. The KMC X11 on my Diverge has done 1650 miles and still going (hopefully through this winter!). I've got 2 new PC1130's hanging around ready! (personally the best 11 speed chain you can get sub £20)![]()
How do you all get through chains so quickly?![]()
Ultegra chain lasted me 4000 miles and a replacement PC1130 is going on tonight after 3500 miles.
