- 24 Sep 2015
I meant to say that I reduced my cooking time too, I was cooking chicken breast at 60c for 2 hours but after some advise from you lot I tried it again for 1 hour and do prefer the results.
I did Chicken Breast last night, seasoned with pepper, thyme, rosemary and oregano going way above what you guys recommend as I was out for a few hours, but 2.5 hours at 145f (62.5c), then a quick sear. Was delicious, but will definitely try for lower temp next time.
This thing is an obsession and I can't wait to try out more things in the next few weeks, going to be creating some sort of dedicated tub for it though, as my towel wrapped pan caused a few issues with low water cut offs yesterday.
With regards to batch cooking using the Anova, what are peoples recommendations or any good guides, I'm trying to work out how would be best to cook/freeze/store stuff for easy consumption, so I don't have to have it running every day for a few hours.
I've totally avoided this thread until now, despite using sous vide techniques for years at work, I've never had the facility at home.
Wonderfully, the old dear bought me a vacuum sealer (Andrew James :/ , does the trick though), and a water circulator (Buffalo). I is a happy boy.
Before I get fully involved in the sous vide chat, I'd like to ask if anyone uses their vacuum sealer to compress fruit and vegetables? Discs of cucumber with lime juice and a little sugar work's great with oily fish, apricot and rosemary is stunning as a pre-dessert, or part of a main dessert.
FT, Should hopefully get my icebox next week. Shouldn't take much to modify.
Thanks for the recipe. Liking the look of seriouseats for the pulled pork. Gonna need to get a load more vacuum bags at this rate.
The new carnitas recipe on SE looks lush too![]()
Bags > rolls, ime. I use the ones from Nisbets.
Oh wow those carnitas....
Not going to happen unless you have a chamber sealer. Atmospheric pressure reduction is needed and edge-style vacuum sealers will not do that.Sounds interesting re compressing. Haven't thought about that as a use for my sealer.
I bought my first batch of bags from Fresherpack, my second batch (and the set I'm still using) were from here.I bought the eiffel sealer and want to get a big stock of bags or roll, what retailers /range do people recommend.
