Facebook on Android just eats your battery
15 Nov 2003
Marlow
So I've even tried setting Facebook so it can't do anything without a wifi connection, and it still eats up my battery. Today, with me having hardly used my phone, yet alone the Facebook app, it's used 56% of my battery! :eek:
That's unusually high, but it is always the (if not one of the) highest battery users...
I think I need to look at an alternative app for Facebook that doesn't think it's the most important app on my phone!
Has it used 56% of your battery or 56% of the charge used? They're 2 very different things.
Either way try a uninstall and reinstall, mine doesn't even appear in the top half of my battery usage list unless I'm actively using it heavily.
As a rule, it's the phones top user... Or in the top 2-3 uses...
I think it's a common problem at least on some Androids... Google "android facebook app battery" :)
I've switched to the Lite version of Messenger, it's not available on the Play Store in the UK but you can download the APK from APK Mirror. Much better than the bloated regular version.
Uninstalled the FB app last year when there was a load of stuff about it slowing your phone down and used battery, definitely noticed an improvement.
Might give that Metal app a go :)
Does Metal offer any sort of Messenger facilities? I assume not!?
I'll swear the battery on my phone today is just terrible!
In my experience it doesn't really work flawlessly and feels very beta. Unsure if it is beta or is like a US only?
Yes, Metal has messenger facilities.
I have Metal on my S7 Edge. Didn't notice a difference between that and Facebook in terms of battery. I just prefer Metal because of built-in Messenger stuff. Other than that, it isn't amazing, works fine I guess.
I've always heard this but I can't say I've ever experienced it, as of 19:15 today Facebook has used 2% from phone being taken off charge this morning.
I'm not a Facebook fiend though it should be said, I might bring it up 2 or 3 times a day for a 5 minute browse and that would be it.
Even on past devices I've not noticed Facebook being excessive. I tried metal quite recently but it just doesn't have the same ease of use and cross-app support as the regular Facebook app.
Ok, that is weird. Normally I don't have a problem and my phone is on about 60% after work but I still have 90 minutes to go and it's on 25% and has been running warm all day! Facebook is in 27% usage today and messenger, which I haven't even used today is showing 25%!
