- 17 Jan 2015
Mine was definitely chewing my battery today. I have the app installed, but I haven't been using it, and its set not to do any background refreshing or notifications unless the app is opened and refreshed manually. Instead, I have been using the mobile site.
I am seeing more and more issues with facebook (app) these days. For example, more often than not, if I tap "comments" then tap on "....replies", the keyboard nearly always pops up as though it thinks I want to type a reply - annoying when you only want to read it having to dismiss the keyboard each and every time.
More recently, I can just be scrolling down and the "Cut/Copy/Paste" menu just randomly appears as though I've held down on a post.
Also, if I scroll the end of the comments it's too easy to dismiss the entire comments box by mistake.
The mobile website doesn't seem to suffer the same issues.
That being said, there it was, 2 facebook processes chewing my battery when I turned on CPU usage, when I realised that I only had < 20% battery left in a day when I'd normally be in the 60s.
Phone S7 Edge.
Phone S7 Edge.
its massive, metal today hasn't even used enough to show up as 1% of battery.
