Hmmm so i7 v s7. Heard that one somewhere else......
Fingers crossed the s7 doesn't explode this time
yeah, I know it was the note 7 not the s7, but joakes
Are you sure? I haven't seen anything indicating the CPUs will actually be called "AMD Ryzen ...". The SR3/5/7 moniker was seen in a single slide but personally I hope they don't use them. It's unnecessarily confusing for an 8 core CPU to be called SR7 (for example).Ryzen is the Marketing name, like Athlon, Phenom, Pentium, etc
S7 is a performance tier differentiator, like i3, i7 etc
- $499 (SR7B), 8/16 (core/thread) L2: 4MB, L3: 16MB, core speeds 3.6Ghz standard, Turbo to 4GHz (coor speed for 3.6GHz was confrimed as SKU3 being used on the Doom demo).
- $349 (SR7), 8/16 (core/thread)L2: 4MB, L3: 16MB
- $249 (SR5), 6/12 (core/thread) L2: 3MB, L3: 12MB
- $149 (SR3), 4/8 (core/thread) L2: 2MB, L3: 8MB
Anything that's cache and memory interaction intensive will likely be in Intel's favour, but I wouldn't hold either vendor to that till we see results.
Details below as I have read:
So what has happened is that Summit Ridge is the main architecture and has been given a branding name of Ryzen for desktop chips.
The server and APU's are still using their code names Naples and Raven Ridge. These are likely of course to be renamed otherwise. The codes are SR3/5/7 to be able to easily understand what they compare too from AMD's view in regards to Intels counterparts. That makes sense.
I have no issue with it being called AMD Ryzen SR7 for instance.
With the above I would say that it is a good step forward but still a generation behind Intel. If they had just managed to push it so that they could have got closer to the 4.6GHz in turbo across all cores and I would see everyone almost migrating across to AMD. what will be interesting is with the less cores on the SR3/5 series is how they boost. Could be for gaming if they boost closer to the 4.6GHz they will be better anyways.
Although I am not very savvy on CPU's so not sure how the L2 & L3 cache will relate to that performance.
oof. those prices look too good to be true. could see each shifted up one with the top being more like $650 and a 4c4t filling the bottom slot.
Which would still be a fair bit cheaper than the intel equivalent
£250 for the 6 core 12 thread is way too good to be true.
Intel's highest clocked 8core part runs at 3.7Ghz turbo, their highest clocked 6 core was last gen at 4Ghz, with Broadwell-e it's only 3.8Ghz.
But 4Ghz boost for AMD is a 'generation behind' because it won't hit 4.6Ghz, which nothing Intel make above 4 core comes remotely close to? PS that 6 core 4Ghz part was $1000, and the current 8 core 3.7Ghz part is $1000, the current 6 core broadwell-e at 3.8Ghz is $660 or so.
Rumour source for those prices is wccftech on November 25th, reporting on a purported presentation slide leak that came via www.chiphell.com
http://wccftech.com/amd-zen-8-core-35ghz-cpu-spotted/
Make of it what you will![]()
Can't see the image but are you comparing a 4c/8t Zen with a 4-module Piledriver?spotted something, estimated Cinebench R15, whose estimates? they are kinda low scores, the 8 thread Zen is about the same as the 8 thread Pildriver.
