of course clock speeds are not going to magically increase.
the temp reduction means there is more headroom to increase vcore to get extra clockspeed.
I presume he meant that the failure to achieve a higher stable overclock wasn't very good.
He wouldn't know. Because he didn't try a higher voltage than what he did beforehand.
I'd be happy with the same clock and just a cooler system!![]()
your system won't be cooler. the heat generated from the CPU is more efficiently taken away from the source and dumped into the case/cooling system.
Think about it. more volts and more current = more energy; laws of entropy, all energy turns into heat...so more energy more heat. a system can't be cooler if you are throwing more energy into it.
If you are not using AIO water cooling then chances are your case is getting hotter as opposed to cooler as more heat from the CPU is being sucked up by the heatsink and being diverted to the air circulating inside the case.
