Suspended
- 18 Oct 2002
There was a lot more ways you could use them - problem is a lot of people didn't put much imagination into it though it was largely a role for an alt.
I did have a combat orientated Eos that could run 2-3 links and do a lot of damage as a hands on ship but mostly minimal hands on setups.
For PVE I used 6 link command ships quite a bit - largely sat at POS (or just off the POS after they prevented links running inside a POS).
One setup I had was a "buffbot" Eos that I could "slave" to my main if it was flying a guardian or something like that - which combined a fair few minimal hands on capabilities as well as meaning I didn't have to fully rely on anyone I happened to be in a team with being competent - been awhile so this might not be the final fit I had:
(Though I mostly ended up using it for PVE rather than PVP).
Am I correct in thinking it isn't possible to use more than 3 command modules on any hull now?
