So, is it a mix choice that you emit clouds of vapour? Can you change what/how you are doing it so not to do this or is it part and parcel of vaping?
I need to know what i'm talking about so I can act accordingly, I think he is doing clouds of "I'm a vaper and everyone should know" and he has no need to do this at work but I need to know if thats true![]()
I do this because I'm not a dick - I'm a considerate vaper in the same way I was a considerate smoker. I would explain the situation to him and tell him if he doesn't moderate his vaping, you will be forced to impose a ban. If he has any sense, he'll realise smaller clouds are better than none.
The smoking point/shelter/thing should (ideally) be far away enough from the non-smokers that the cloud chasers don't impact them either.As an employer I've allowed people to Vape as it is outside smoking laws, now i'm starting to get grief from non smokers about the vapers, or actually one guy who emits clouds of vapour.
I don't want to ban it, there are a couple of others who do it and nobody really notices but this one guy is liable to spoil it for all.
It is completely a choice to use high VG liquids in SubOhm tanks, yes.So, is it a mix choice that you emit clouds of vapour? Can you change what/how you are doing it so not to do this or is it part and parcel of vaping?
IN the factory??!!We're not talking about a smoking shelter thing, we're talking about in the factory where smoking is not permissible so vaping is being used as an alternative by a few.
IN the factory??!!
That's a big no-no, regardless, then - Unless every single employee vapes, you're impacting too many or your workers.
Send them outside.
Well, if you wanted to use the law as a threat - While there is no actual law against vaping specifically, the general wellbeing and happiness of everyone else trumps his need for huge clouds of strawberry-cherry-berry.Its not really how the law has it afaik, vaping indoors is permissible although discretionary and I would rather leave it as so but for this person.
I don't think you've caused any issue at all, mate - It's good to discuss these things, especially with those who aren't vapers.Anyway, I never stepped in here to cause issue, i'm here to get facts from people that do it which I have.
Thanks, thats great information which I will pass on.![]()
I do find the fill port a bit tight on some glass pippette tops and the twisty nozzles are just impossible to fill with...I don't think I will bother revisiting my Cleito/Crown tanks since getting the Smok Big Baby Beast, the fill mechanism is genious and a joy to use!
Just popped my cherry on my first proper DIY batch, well, one shot concentrate at least.
2x100ml Vampire Vapes Heisenberg
1x100ml NovaVapes Strawberry Milk
Going to start checking out some popular recipes and begin buying some flavour concentrates.
Question: why doesnt http://e-liquid-recipes.com allow you to properly sort redipes by most reviews first to help highlight the most popular ones? It seems it allows you to do it, but the order seems out of kilter?
What's the Heisenberg like?
It's a concoction of aniseed, menthol with a fruity undertone. It's 'one of those flavours' that everyone should at least try![]()
I meant the concentrate, I know what the actual flavor is![]()
