- 17 Jun 2010
- London
KiNgPiN83;30499717 said:What are peoples opinions on lifting shoes? I don't believe i need to go full Adipower or anything. (Plus they are pretty expensive..) Although I'm not adverse to paying for something if it will genuinely help me out.
So other than that, how do you guys roll? Flat converse style 'skate' shoes? Bare foot?
They help in two ways. One isn't specific to them, one is.
1) Stability. They're solid so you're not leaking energy wobbling about on a foamy heel and most of them have a slightly more spread out sole than a typical trainer, which improves lateral stability (makes it harder for your feet to cave-in).
2) The raised heel means in a deep squat position it's easier for 99% of people to keep their hips closer to their ankles, which makes a vertical torso position easier. This is desirable for Olympic lifters since a) they squat to full depth and to get strong legs and big quads, and a more upright squat is a more anterior (quad) dominant and b) it makes the overhead position easier in the snatch, since holding a weight directly over your head is a lot easier stood up than if you're leaning forward.
The trade off for this is that technically you're making the pull off the floor a little harder since it's almost like a slight deficit, but since even clean weights aren't maximal pulls like a deadlift it's not really a big deal. This is why if you go on Hookgrip or ATG you'll see every professional weightlifter wearing shoes with an elevated heel.
So to actually answer your question, it depends on how you squat really; any sort of deep high bar squat or front squat will be made easier with lifting shoes. Also if you're cursed with long femurs which make maintaining an upright position very challenging, they'll reduce the amount of lean a little by default which is always helpful if you're not built to squat but plug away at it regardless.
