OK if that's true, then this CPU is looking pretty epic based on this older bench run I've seen of a 5820K (Source: Techpowerup https://www.techpowerup.com/forums/threads/share-your-cpuz-benchmarks.216765/):
That Ryzen being CPU-z'd is also 6c12t and much lower clocked than the 5820k!
So if the benchmark ran on that Zen at around 3.3Ghz, it has (in this benchmark) extremely competitive single thread and genuinely excellent MT scaling. Even if it's boosting to around 3.5Ghz on all cores, it's still extremely good performance.
Choo Choo hype train!
6c12th Ryzen CPU at stock (up to 3.8Ghz), showing around 10-15% ST performance improvement versus 2500K running at 4.4Ghz, MT performance improvement around 100%
Will be really interesting to see performance on these things once clocked, especially for those of us with older CPUs.
If there's a reasonable chance of a 20-25% overclock, then the excitement shall happen.Has it been confirmed if the boost is on all cores or a single core?
All the same, can't put too much weight on low detail numbers outside a proper review.
Still, can't blame a chap for hoping ^^I don't think they'll give an all cores boost number, there is just too much variation. Intel doesn't do it either as it's just too complex to do.
The 6900k has a base clock speed of 3.2Ghz and a single thread boost of 3.7Ghz. All this is saying is in the worst case scenario, the most power draining application possible all cores will run 3.2Ghz, then the absolute top speed of a single thread is 3.7Ghz.... it's not making a statement at all about what the best turbo is for more than one thread, nor is it stating it will only run 3.2Ghz with 8+ threads. All cores can turbo to anything between 3.2-3.7Ghz and it depends on the application. Keep in mind from what I've seen the 6900k will hit 3.5Ghz on all cores for most people and it ran 3.5Ghz under boost in that handbrake comparison with Zen, despite having no official all cores boost.
But those are the two simple metrics, a single thread won't go above 3.7Ghz and all cores won't go below 3.2Ghz. I expect AMD will do the same, so for that 1800x likely 3.6Ghz base clock 4Ghz single core turbo, then some applications will run 8 cores at 3.8Ghz, some at 3.7Ghz, some at 3.6Ghz. Being an 8 core in a 95W TDP it's likely to do less well in terms of boost on all cores strictly within TDP. If you overclock, which might just be a case of raising the TDP you want to use, it might boost all the way to 4Ghz in everything.
