Fidget toys are probably one of my favourite things at the moment, I have a few different things on my desk at work to keep my idle hands busy and to stop fiddling with pens or whatever else I can get my hands on. They're also claimed to be good to help with anxiety, autism and ADHD.
Fidget Spinners -
These have only became a thing within the last 4 months and are my personal favourite fidget toy. They're a ball bearing which can be ceramic, hybrid or steel and surrounded by a body of metal (Copper, Brass, Stainless steel, Titanium) or plastic. These range from relatively cheap to insanely expensive. What do you do with them? Just spin them of course, and these things spin for ages if you get a good one (4 minutes +).
Spinners:
(I've selected one spinner from each company, for the most part they have a few different ones to buy)
Spinetic - Ranges from $34 - $39
NobleSpin - Ranges from $39 - $99
Torqbar - Ranges from $139 - $199
(Highly regarded Chinese knock offs can be had for $17 from www.3Fvape.com)
Spinner.vn (Hyperstone) - £64
Rotablade - Ranges from £95 - £165
Flyaway Toys - Ranges from $35 - $119
NTO Designs - Ranges from $52 - $149
Goldundmesserschmiede - 149,00 €
2rdesigns - Ranges from $50 - $85
RPM Corp - Ranges from $55 - $100
Fidget This - Ranges from £32 - £45
Zerofued - Ranges from $55 - $180
FromRussiaWithKnives - $173
3D Printed spinners -
These come in all shapes and sizes, and range from £15 - £50 on Etsy.
Other fidget toys:
Fidget Cube -
https://www.antsylabs.com/products/fidget-cube
Lots of people will have heard of this, a cube where each side has a different thing to use to keep your hands busy by clicking, gliding, flipping, breathing, rolling & spinning.
Fidget Rings -
https://www.etsy.com/uk/market/fidget_ring
These are all over Etsy, some cheap, some very expensive. A ring you wear which has twistable things around the outside of it. A lot more discreet than the cube and other fidget toys.
Fidget Chains -
https://www.amazon.co.uk/Chain-Fidget-Autism-Stress-Hands/dp/B01N1WEHE1
This fidget toy is relatively inexpensive, made from a bike chain normally with loops going through it. Haven't tried one of these yet, however it gets really good reviews.
			Fidget Spinners -
Spinners:
Other fidget toys:
Fidget Cube -
Fidget Rings -
Fidget Chains -
