Not surprised it drives better now!
Those 19's have like no tyre at all it must have being bloody harsh and literally jumping on the road with those rubber bands for tyres?
This, as much as i like my 19" CSL "style" wheels on my Z4, it is a harsh ride and the wheels do actually jump all over the road, unless your on smooth tarmac good luck taking a corner in them. Hoping to downgrade mine in the next few months to 18" something like the MV2.
what tyre size is on your new wheels Grudas?
Around half a litre of fuel per mile, at least they were probably fun miles so well worth it.
I thought I've been taking it easy with all these greasy conditions so I was expecting to get good mpg....
The last tank included around 180 miles of motorway which upped the average.
standard Z4 coupe sizes so -;
front
225/40/18
rear
255/35/18
Z4M Style 224 wheels have different offsets compared to stock Z4 style 108's for e.g. wider track is the only difference here, rear fills the arches very well! front could do with a 5mm spacer but I'm not fussed.
Tyre prices are sooo much more reasonable than mine.
yeah the 19's on mine are 235/35/19 and 255/30/19 on the rear.
think it was 150ish extra for a set of tyres.
I paid £440 for a set of goodyear eagle f1 as3's
A lot of cash I could be saving.
do it! get a set of style 108 or even 224's like mine if you can find a set and the ride will me a million times better!
have you had smaller wheels on your z4? if not then I'd say you're missing out as the difference is crazy.
I would offer you my 14" bottlecap alloys with balloon tyres to try, but they are the wrong fitment.![]()
Would be like floating on air.do it! get a set of style 108 or even 224's like mine if you can find a set and the ride will me a million times better!
