I hope it's not pointing to limited overclocking headroom.
So far I'm impressed. Everything Silent Scone has said is truth and gospel about Ryzen has turned out to be utter rubbish. No 3000+ ram support , no 4ghz cpu....
The sky is falling everyone cancel your pre ordersUh, what's with the new french site leak? everything looks good but a simple 4790K is faster in gaming and the conclusion is that it's a good 6700K aletrnative money-wise, is that from an old 1700(X) sample?
Uh, what's with the new french site leak? everything looks good but a simple 4790K is faster in gaming and the conclusion is that it's a good 7700K due to the pricing, is that from an old 1700(X) sample?
If you shift the goalposts enough, you're bound to be right eventually. Keep at it!lol
https://forums.overclockers.co.uk/posts/30430250/
You can argue with 8-Pack if you think you'll get more than 4Ghz
"new" as in december last year with an engineering sample?
Were you expecting anything different?So far I'm impressed. Everything Silent Scone has said is truth and gospel about Ryzen has turned out to be utter rubbish.
I am waiting until I have read several reliable reviews to see what Ryzen can do.![]()
With similar IPC, for low-threaded games this is to be expected due to the lower clock speed.Uh, what's with the new french site leak? everything looks good but a simple 4790K is faster in gaming and the conclusion is that it's a good 7700K due to the pricing, is that from an old 1700(X) sample?
i think in many games a 7700k is obviously going to be in front.clock speed in most games does matter but...ask anyone with a modern 6 core plus machine who uses it daily would they take a 7700k over it most wouldnt.multitasking is more common people are streaming and recording gaming more often now it just makes sense.
its pretty obvious that is going to be gaming intel probably still infront by quite a bit on the whole multitasking up with x99 lower tier platform.intel x299 will adjust that balance when its out.
it is kinda funny that for last two years many have mainly wanted more clock speed or denied wanting more cores but now the pricing is decent then the more cores is attractive.especially on older i5s and older i7s.when you could have had this performance as said a few years ago for not too much more.![]()
