I'd ignore test, 1700, base is 3.0GHz, turbo is 3.7GHz, AMD do this so it qualify as 65W part. If you switch it over to manual mode in a good motherboard like Crosshair you just lock it to run at 4GHz all the time, then the performance is vastly better, even beats 1800X.![]()
The issue is how far the 1800X can clock. The AMD CPU overclock software has max speed somewhere around 6.3Ghz..... which I guess that's LN2 territory.... but what it can under water? 4.5?
And until reviews come out, holding off
even if part of me want to buy the Asus Crosshair, the1800X and everything else I need for the custom WC of the system.
