It's all the same silicon so it'll all behave the same reaching a wall around 3.9 and quickly topping out ar 4.0-4.2ghz. None has tried individual core clocking yet though. The advatange to the r5 is the price to performance will be unbeatable.I'm seeing a lot of people hypothesizing that the 1600x, as a gaming chip, won't clock too much higher, if any, from what we've seen from the 7 series. With this in mind, is it really worth buying over the 1700x? I'm at a point right now where I'm waiting for the 1600x, but seeing the gaming results of the 7 series I would rather pay a little bit extra and take the 8 cores, with potentially similar gaming results to what the 1600x will deliver.
What are peoples' personal opinion on the 1600x's potential overclocking abilities, based off of what we have seen so far?
Has anyone benched any games yet, While the synthetic becnhes look impressive I would like to see some users game benches!
Basically the 1700 should be the best buy for overclockers, the 1700X otherwise. Whether the 1600X will be viable depends on its price and TDP - if it has higher temps and voltages than the 1700 at ~4 GHz then it's probably a dud in the SKU line-up. If you want better overclocking you're going to have to wait until Zen+.I'm seeing a lot of people hypothesizing that the 1600x, as a gaming chip, won't clock too much higher, if any, from what we've seen from the 7 series. With this in mind, is it really worth buying over the 1700x? I'm at a point right now where I'm waiting for the 1600x, but seeing the gaming results of the 7 series I would rather pay a little bit extra and take the 8 cores, with potentially similar gaming results to what the 1600x will deliver.
I honestly think the best thing about the 1600X will be that it forces reviewers to redo their 1700(X) and 1800X tests with an actually finished ecosystem. We also are getting reports that Ryzen loves higher RAM speed (at the expense of timings) because its data fabric has a locked ratio to the RAM speed. Could be another reason Joker got better results with his 3000 MHz RAM if mainstream reviewers were mostly using 2400-2667 MHz RAM.
Best thing AMD have done is to spread the launch of the chips
now if it was meant intentionally or that they where not ready to launch the entire range its better suited this way more reruns with reviews and by then bios / mem win 10 update of the scheduler maybe fixed ...lets hope so
The 1700's probably flat out the best chip to buy right now.
What it offers for 320 quid is absolutely mind blowing.
Uh-oh. Slightly worried for when I get home now and I unpack my hero.Rumours starting that ASUS may have pulled the hero from sale.
Mainly stemming from Amazon taking them off preorder, so could literally just be supply issue.
I've just checked and it is indeed showing as unavailable.
Just update the bios before you starting fiddling, so you don't brick it.Uh-oh. Slightly worried for when I get home now and I unpack my hero.
hello and welcome. very interesting first post - even if I don't understand it fully!![]()
thread affinity solution could be done on the software side
Roger doger. Right into the bios with a flash it is.Just update the bios before you starting fiddling, so you don't brick it.
Another review who says games run smoother on these chips than they do on Intel. how many is that now?
@ 14 Minutes
