Caporegime
- 9 Nov 2009
- Planet Earth
Explains a lot now Joker Video defo shows this stutter.
Now imagine if Bethesda can get Vulkan into the next Elder Scrolls!
Now imagine if Bethesda can get Vulkan into the next Elder Scrolls!![]()
They may well not be. But thats not to say it will perform any worse than intel does in that same scenario. I've never played fallout or skyrim but I'd imagine it would affect CPU's all the same, not just one.
I haven't played a single Bethesda game since Morrowind really. I might one day, but I bought FO3 and it refused to even run on Windows 10, never tried again.
Also Computerbase are including frametimes now for their CPU benches.
Multiplayer BF1 is looking darn good on Ryzen.
Bloody hell, I hope AMD can sort out their Gaming performance issues! It's the only thing holding this launch back!
now i would like to see the Intel 8 core resultsNow that is what i want to see.... would you look at thatnow i would like to see the Intel 8 core results
1.312v at 62 degrees for all cores under heavy load seems great to me. I'd probably be tempted to try 4Ghz.
Higher frame rates for smoother gameplay, but what if you have smoother gameplay with lower FPS?
*heads are about to explode*![]()
1700 - 10 mins runs with Realbench stress test temps with Noctua NH-U12S
These chips are getting more and more impressive.
What do you people think I should sit on for 24/7?
To be fair to Intel, that Computerbase article also shows that's it's only the mainstream CPUs which have this stuttering in Battlefield multiplayer. The Intel HEDT CPUs like i7-6850K performs only a little worse than the Ryzen 7 1800XMine has all ready exploded as soon as i started hearing a trend with the reviews stating they thought things where smoother with Ryzen ......So it does look like its taken the Ryzen release to show us how bad ..maybe a bit strong there ..to show us what weaknesses Intel chips may have ....the fault is really been no competition so Intel have just been drip feeding it and not really improving things they way they really could have been if AMD had still been in the game ...
Because my last post was somehow lost... is here someone who already used this AMD Master Tool to OC? If so do you recommend it?Have you got any idea of the power consumption for those clocks and voltages?
Even if you don't have a mains power meter, I believe HWiNFO64 can read the package power which should give a relative idea (minus VRM and PSU inefficiencies).
With the software overclocking utilities like AMD Ryzen Master Utility and the ability to change profiles without restarting, I would be tempted to create various different ones like a extra low power one like your 3.6GHz and a high power profile like your 3.9GHz one.
Because my last post was somehow lost... is here someone who already used this AMD Master Tool to OC? If so do you recommend it?![]()
Great News for meUse it, its very good.
so i dont have to mess around in BIOS/UEFI... I'm totally new to OCing but got somehow excited about it and since I planned to do a completely new build this was a big thing for me hehe. I need to ask this because I cant find the answer and its confusing me
Is a non X Ryzen when OC'd to match an X model across all cores and is an X models quoted turbo speed guaranteed and across all cores or is it just single core above base clocks?
Thanks
Great News for meso i dont have to mess around in BIOS/UEFI... I'm totally new to OCing but got somehow excited about it and since I planned to do a completely new build this was a big thing for me hehe.
Do you also suggesting to go with the 1700 and try to get 4 GHz. Some guys in a shop told me that the 1800x should be best to OC but all this forum says otherwise... I'm a bit confused right now lol.
Boost is single core, non X matches X models when running at the same frequency.
Basically unless you don't want to overclock the 1700 is the only one to buy
