I think its normal with the X? I have 110I but changed the fans to Noctua NF-A14 3000. If you have on auto it will go up and down all the time from 3.4 - 3.8GHz -+ Volts. Mine 1800X have same temp idle 53-60, clocks goes from 3.6-4.1 on 2 cores. When I do nothing. Have ca 60-65C when I game. But have seen someone says the new beta bios for CH6 shows 15+ degrees too much. There is no warm flow from the radiator soo something is up
And 1700 have - 15-20C just beacuse its a none X.
