I'm sending the foot guard back, no charges he accepted the return request without any problems. I bought a new one from a different place, that should be with me on Tuesday possibly.@IC3 , if that a foot guard thing? Looks quite bent to me mate.
Does it screw in ok?
Do you want me to pop down to the breakers and get some pictures of the bars? There are three different sets he had I believe.
They're, I'm going with different pads next time round.I find EBC to be extremely overrated tbh.
I wish!!!
Just the standard 2 pot Nis calipers. But, find them to be really good for their size.
I've tried ebc before, they were okay, just thought might try brembo out.
You are right there. They look similar to the tok calipers you get like on the sv, er6, bandit etc etc and find them so nicer to use.The non-R Street Triple brakes are actually fantastic. The are less "grabby" than the R version. It's just a shame the suspension isn't as good.
It is a DJI Mavic Pro - I chose it because it is so portable. It can follow and track you but it has limitations, so everything in the video was just shot manually. There are some third party apps that can follow preset waypoints. Should be an absolute hoot in the Alps later this year![]()
Friend in work bought a new KTM 690 duke a short while ago, since doesn't like the riding position and went into part X... However his misses kicked off and said he's not selling it.
They only offered him £3500 - £4000.... I offered to buy it cash sale, what type of price is fair for a private sale would you say? I think its a 12 plate
