- 28 May 2007
Are you serious?
I have got 4 of AMDs fastest card which do support quadfire and now run pretty good now they have finally sorted out the drivers.
The funny part about it is that NVidia only support 2 way SLI yet 4 way SLI does run very well - AMD support 4 way Quadfire and up until recently it has been awful since the introduction of the Fiji cards, fortunately they have finally got it running properly.
My problem with DX12 is it is a new API that should give better results with hardware going forward, something that is not happening at the moment as there is too much extra work for the game devs. A new API should not be judged by what it can with old hardware as this is a journey to nowhere.
So your problem ain't with DX12. It's with the game Devs. The same Devs who some off were begging for dx12 yet won't use it properly. Full of BS they are. Saying that it does take them a good while to utilise a new API usually. Dice especially should be using it to better effect as they were also behind Mantle and pushing low level.
