i turned it off and the temps looked better to me
Explain?
I believe it was reserved for the high end boards, this was one of their selling points.Installed the latest beta bios for the MSI B350 Tomahawk. Can now finally run stable at DDR4 3000Mhz. Can boot at 3200Mhz but not quite stable yet. Also noticed the new bios has CPU BCLK adjustment settings. I thought this was reserved for the top X370 boards??
Temps look a lot worse to me it's idling at 40c in a 23c roomi turned it off and the temps looked better to me
it was better for i. With it on, I was being told that my idea temps were 12'Temps look a lot worse to me it's idling at 40c in a 23c room
Explain?
I doubt this would make a difference to most things. NVMe drives may be different.setting BCLK above 105Mhz officially makes the PCIe link downgraded the PCIe 3.0 bandwidth to 8X instead of 16X
I still don't get why everyone is worried about going to or over 1.4V when AMD warranty is to 1.55V and recommend 1.45V for 24/7 clock.
With that in mind for people gaming an overclock with 1.55V will be fine technically.
From now on this will be my go to stress. I knew something wasn't quiet right when overwatch was continually crashing despite lowering RAM speeds and using the same GPU in a previous build that was rock solid.Been using Linpack for years, always found that if it'd pass 10 max loops of that it'd pass anything!
It had passed everything before it. But as I said 40 minutes in brought it to its knees.
Are you still seeing better performance than anyone else using hpet off?
I still have the same as before yes. I have no idea why though. I'm going to turn it back and off to see what happens. As someone stated it could be a timer error. One thing I do notice is with HPET off my minimum framrates in heaven benchmark drop to single digits then immediately back up to 100 or whatever. Other games/benches seem fine however.
Yeah, that is why I wanted you to do some timed tests rather than fps measurement, to see if it really is faster or just an error in measurement.
Intel burn test on a Ryzen CPU. The irony.
So you set it to extreme and 10 loops? That's a good stability test?
