*******quickly types email to hq********
Good News Everyone!........
huh, cryptic message. lemme thing..... aaaa
Is it the LG 32UD99 coming out at 100+hz refresh rate and Freesync 2?
Same was said about 4:3 etc.![]()
It does seem like more people generally prefer a wider FOV/display especially for media consumption, which is why 16.10 lost to 16.9. Even the new phones this year are jumping to a wider aspect ratio. And we will probably see some more 21.9 laptops at some point too given the increased horizontal space, we even got a powerhouse 21.9 laptop now as well:
The only thing that really holds backs 21.9 TVs is that the vast majority of TV shows are shot in 16.9, if TV shows switched to 21.9 then we should see a lot more 21.9 TVs made and as a result consoles would also switch to 21.9 or at least support it.
But yeah I don't expect 16.9 to go anywhere for a very long time, if/when TV shows switch to 21.9 then I expect to see a huge surge.
Just had a look at steam survey and 4k has gone up a lot:
21.9 res. still in the lead for now.....Either way, that still isn't bad considering 4k monitors have been around for far longer, as well as a far bigger choice as well as being cheaper.
But once again, remember that 4k is just a resolution it and the benefits a higher resolution/PPI brings isn't limited to 16.9.
EDIT:
Heck, even 21.9 aspect ratio isn't exactly limited to dedicated 21.9 displays as you can create custom 21.9 resolutions on 16.9 displays.
That would be lovely. And don't forget, no aggressive anti glare coating!huh, cryptic message. lemme thing..... aaaa
Is it the LG 32UD99 coming out at 100+hz refresh rate and Freesync 2?![]()
Of course they aren't exactly accurate but they do give a good idea as to the trend of hardware & software.I take those "surveys" with a grain of salt. 1/4 of all people on steam use the resolution "1366x768"? You mean to tell me 1/4 of all Steam users are using a laptop resolution from 15 years ago?
That monitor looks too expensive after looking at the reviews imo.A) The recent AOC Agon AG352UCG model has G-Sync but no ULMB
http://www.tftcentral.co.uk/reviews/aoc_agon_ag352ucg.htm
B) Not with ULMB but the Eizo Foris FG2421 and the more recent EIZO Foris FS2735 have their own built-in strobing which does not require a specific GPU or OS to enable. Just enable it in the monitor settings. For me this is ideal.
http://www.tftcentral.co.uk/reviews/eizo_foris_fs2735.htm#blur
Daniel, maybe you should listen to the engineers from LG instead of asking here. What's the best monitor LG produce?
Well, while Daniel is at it, he should also ask what upper management and the CEO want also?Daniel, maybe you should listen to the engineers from LG instead of asking here. What's the best monitor LG produce?
100Hz 16:10 2560x1600 or 2880x1800 with VVR. Is that possible?
