Hi All,
I have tried to keep this short and I am about to give up on it but I thought someone on Overclockers could sort it.
I updated the firmware on my SSE supplied router to 15.4 from 15.2 using the file on Nick's site and since then I have been using a USB drive formatted to NTFS for about 3 months.
The drive is a Crucial M4 SSD 128GB SATA 6Gb/s and I have used a drive Adapter ( USB3.0 SATA ) that has 2 flying leads 1 is USB power supply, the other is a USB 3.0 port. I have had both leads plugged into the router just in case but it does work fine without the power lead.
But in the last week, the drive stopped showing up on my Samsung TV which is hard wired to the TG589vac Router using one of the Lan ports.
Without fail the router drive always showed up on the TV as an AV source using the Linux Penguin icon as shown it the picture.
Today I tried plugging in my old HP32gig USB drive and it showed up as it should on the PC as Linux and also on the TV and worked fine.
I then plugged in the NTFS drive and it will not show on the TV but does show on the PC just as a Mapped network drive.
I decided the clean the NTFS drive and delete a few folders one called " .dlna " inside this folder were 3 files one of which was corrupt and
I thought I had found the problem. It would not delete, so I had to use right-click/properties/tools/check/repair...........this removed
the damaged file.
But I decided to remove all video's etc and start from scratch and reformat.
Still no joy, it will not show up on the TV, in other words, it is not recognised as a DLNA device, and I was hoping someone on Overclockers could help me sort it out.
I don't understand where the " .dlna " folder came from originally, but I am sure it was the cause of the problem.
