I dont know why you keep saying this and after we've seen the specs.Apparently Vega 11.
4000 cores is a big chip GPU. This is the flagship. There should be no doubt about it.
Vega 11 will undoubtedly be a lesser GPU.
It's 'big chip' by AMD standards in a given range.4000 cores wasn't even such a big chip on 28nm, it was still smaller than Big Kepler on the same process, at 14nm its a good deal smaller than the full fat Pascal Titan.
that's exactly the problem with AMD's line up, they wont have 300-400$ GPUs, they got SKUs from 80$ to 250$, then nothing untill you get over 500-600$, unless they are planning on pricing vega between 350-500$, but as i said before looking at the packaging i doubt that's their aim, especialy with AIO cooler...and i do not believe AMD has another vega chip except from ( full/cutdown variants)Who knows, maybe AMD will put out a £300 card at least as fast as this 1070, if they do this will be a short stint owning this GPU.
Yeah, i actually sold my 970 before i could get the 1070, so i ended up lending a 290X from a gaming friend, i just happen to have this Free Sync Screen
It was nice, certainly i noticed the smoothness and lack of any input latency immediately, it does fool slinky and very responsive and i have to say i do miss it now that i no longer have it.
I think it's pretty obvious what we're looking at here.
although downside suggests not much room for overclocking agianused to strip the graphics cards down, block them then shove them in a custom loop (which i hated doing). the fury x was my first AIO and i love the look of ithem.. I do hope they keep it as classy as thatalthough downside suggests not much room for overclocking agian
I'm interested in the here and now that IS the bottom line... no smoke with mirrors is going to deviate me from that. Water cool Vega and you're up against a water cooled 1080Ti end of story.
What Standards? you say that and yet history clearly proves you wrong, the Fury-X was still a pretty big chip, actually a little bigger than big Kepler as i have been corrected ^^^^
The 7970 was also much larger than the GTX 680. the 290X was a pretty big chip too.....
AMD are quite capable of making chips as big or even bigger than those nVidia make, when they want or need to, and they have.
Big Pascal is 600mm2^, a 14nm Fury-X isn't going to be anywhere near that big, AMD have plenty of room to grow into, another 50% probably for a 6000 core GPU.
Trouble is , even with HBM it looks like they are nearing the power wall. The card spec listed already has a 225 tdp so there is much room for maneuver unless they are going to release a card that runs very hot and power hungry.
I mean if they were to release a mammoth 6000 core gpu what would the tdp be if the 4000 core card is already at 225!
Trouble is , even with HBM it looks like they are nearing the power wall. The card spec listed already has a 225 tdp so there is not much room for maneuver unless they are going to release a card that runs very hot and power hungry.
it would be way over 300w most likely, especially since you would want 16GB HM2 to make it work while. And I don't think a 6000core GPU would scale nicely at all. the 4000 cores on the FuryX were a bit of a disaster as there was so much bottle-necking the GPU never lived up to 0its theoretical throughput. AMD seem to at last be doing the sensible thing and instead of trying to brute-force performance are actually trying to balance the GPU design and better optimize the pipeline. Big Vega will have a similar 4000cores to FuryX but the increased transistor budget will be spent on making those cores work more effectively, especially in DX11.
You misunderstand TDP, its not power consumption, its a thermal thing.
Besides that 225 Isn't high at all. nVidia's big Pascal chips are higher than that.
We have heard the size and power consumption arguments before, for the same reason it was argued to be impossible for AMD to match the original GTX Titan, in actual fact they did more than that, AMD beat the original Titan and did it with a significantly smaller chip.
A lot of hyperbole here....
Here we go again.
Here we go again.
Here we go again.
1st off - I never said 225 is that high. It is when someone says AMD might be able to do a 6000 core version when the 4000 core version is already at 225 though.
Yes the Titan X has a 250 TDP but the 1080 has a 180tdp. If you do the maths the 40% or so extra cores has resulted in a 40% or so higher TDP.
so 50% more cores on the same vega architecture could well result in a TDP of ~340 which is quite high.
and secondly - AMD beat the original Titan with a new architecture, we are talking about expanding the same architecture basing it on the 4000 core version having a 225 tdp (assuming those specs are correct)
Nothing that has been said is hyperbolic. It is just common sense. I never said it was impossible. It just seems very unlikely given the TDP figure.
