I never once stated the Quadro cards used different cores?
The way I read that he's saying just the gaming cards have gimped compute, when in fact also the Quadro cards do.
The Tesla 100 is the first NVIDIA card since Kepler to feature full Compute performance and FP64, as even the Quadro's don't have it.
Where as the original thread of ours was about AMD's older cards from Hawaii and prior never had that issue; the top gaming cards had the same compute as top FirePro.
So I surmised that it could be the reason Vega is so darn big considering it's core count; which could mean that they went back to that design of huge chip ( 500-540mm2 ), and using it for top consumer as well.
Instead of like NVIDIA which has separated those lines now, DP and FP64 only available on G/P100 610mm2, and everything in the Consumer and Workstation line "gimped"
All of AMD cards are also compute cards, the 7970, the 290X, the Fury-X the RX 480, so the reason Vega is so big on 14nm compared with Fury-X... or any other AMD card you may cite is not because Vega may also be a workstation card and [Insert name of AMD card here] was/is not.... is flawed. THEY ALL ARE!
