Nice, but that CPU cooler is chucking hot air into your case??
Not if the fans are on pull but yer, not the best way to keep everything cool in the case.Nice, but that CPU cooler is chucking hot air into your case??
Wierd... Why does all the build videos build the same way, and doesn't the back and top fan suck the air hot air out??Nice, but that CPU cooler is chucking hot air into your case??
Yeah, if hot air goes in case his graphics card will be sucking in hot air also, so will likely get less boost. Depends though on how CPU intensive the game or task is I suppose, as that rad won't get very hot otherwise.Not if the fans are on pull but yer, not the best way to keep everything cool in the case.
Week late, but here it is. My first ever Nvidia GPU - EVGA 1080 FTW. Coming from an R9 290 (which wasn't bad by any stretch) it's a huge upgrade! Laughs at everything I've thrown at it so far, nice to have so much power
As was noted in the cases thread, my amp extreme is sagging slightly. Any ideas to support it? I might try and rig something up with some cable ties.
It is beautiful though![]()
My 1070 is the same. http://imgur.com/dscdtqFAs was noted in the cases thread, my amp extreme is sagging slightly. Any ideas to support it? I might try and rig something up with some cable ties.
Sorry can I just ask , before I bite the bullet and make a decision , it's normal for the 1080s to get up to near 80c ?
thanks![]()
But you cannot see it, unless you look at it straight on. You could also try fishing line.
What case do you have? I have a phanteks enthoo primoDepends on the cooler. My amp extreme Ti maxes out at 66C.
I have realised that my case has a built in support that I removed. But I have also ordered an acrylic card brace off the bay![]()
